Walli Dimmer, not triggering the scene.
Hello, i have 2 pcs of Walli's in the room.
Walli 1 is wired connected to Lamp 1, Walli 2 to Lamp 2.
I created the scenes:
Switch ON Lamp 1 - triggered by doubleclick of button 1 of Walli 2
Switch OFF Lamp 1 - triggered by doubleclick of button 2 of Walli 2
Switch ON Lamp 2 - triggered by doubleclick of button 1 of Walli 1
Switch OFF Lamp 2 - triggered by doubleclick ofbutton 2 of Walli 1
I simple words - single click operates the physical connected Lamp, doubleclick operates remote Lamp.
My problem is, the scenes triggered by walli 1 stops working without any reason, but scenes triggered by walli 2 works fine.
I can run the scenes manually - from iPhone and from web interface and they work.
Both wallis operate normally the physical connected lamps.
Both wallis has exactly the same parameters set.
Questions:
1. How to check if the trigger is sent to HC3 - is there any terminal to view it?
2. How can I reset to factory the walli?
Any ideas?
