Dahua CCTV camera integration
Hello everyone,
i'm new in this forum, i work a lot with security system and i'll try to make a lot of security senarios! ?
i'm a bit in doubt about how the application work, i can see the camera from the home center, but as i open the camera in the app it seems that it does not work.
any idea?
i have successfully added some IPC from dahua and i want to share what parameter i have used:
camera model OTHER
PROTOCOL: http
the pattern of the JPEG is:
cgi-bin/mjpg/video.cgi?channel=1&subtype=1
where channel=1 is the camera channel (change 1 / 2 / 3 ecc in base of your channel  &  subtype=1 is the substream where you have set JPEG
prewiew settings: MJPG
than set IP address
port 554 or 80
JOB is done! if something don't work you may have to check camera parameter in the web interface of your CCTV camera!
now i have only to understand how to see it from mobile, ??
i'm using admin account so i don't thing is a troubble permission connected issue
another curios thing,
if i use this on my NVR5216-4KS2-V2  Which is the network video decoder, i can see the Video door phone camera in H264!! a see that everyone have wrote that it can't be done..
explanation:
i got a VTO4202F that have mainstream (h264) & substream (h264) can't be implemented directly to fibaro.
i use DAHUA NVR5216-4KS2-V2 to record VTO as a securitiy camera 24h/24h.
i have added a new device in fibaro
put the NVR IP address,
username, password, use port 80
cgi-bin/mjpg/video.cgi?channel=YOUR VTO CHANNEL&subtype=1
ta-daaaaa
the job is done!
I hope this will help someone!
8 answers to this question
I want to ask you if your IPc is connected to NVR or no.
If yes, the ip address you used the one for camera or NVR
Regarding the app which app you are using fibaro or home center?
On 2020. 11. 19. at 21:36, MarcoSmartForYou said:
hello
and "MJPEG path"????
    hi ahmad,
    i got IPC with mainstream and substream,
    i send the mainstream (8mp - h264) to the NVR, and the substream with MJPEG as fibaro want
    regarding the app i use the official one "fibaro home center" for android
    hi kopek,
    i have wrothe the path,
    maybe i have not understood your question,
    hi Marco
    I was wondering about the mjpeg path ...
    I found achievements on the marketplace, they work with me as well.
    Except that tablet does not display the image. Yes on a computer and a phone.
    On 11/19/2020 at 9:36 PM, MarcoSmartForYou said:
    Hello everyone,
    any idea?
    camera model OTHER
    PROTOCOL: http
    than set IP address
    port 554 or 80
    explanation:
    ta-daaaaa
    the job is done!
    This solution works for me.
    I use a Dahua NVR DHI-NVR2108HS-8P-S3
    V3.2.7.145103
    IP address 192.168.1.xxx:80
    user admin
    pass xxxxxxx
    JPG stream path: cgi-bin/mjpg/video.cgi?channel=1&subtype=1
    MJPG stream path: cgi-bin/mjpg/video.cgi?channel=1&subtype=1
    The camera is connected by POE of the NVR with the standard IP 10.0.0.xx that the NVR put in it.
    Hello
    http:80
    rtsp:554
    there is no channel set for me on the jpg and mjpg path, but only 1 is everywhere and they work.
    It also depends on the type of camera. What kind of cameras do you have? Series 2 doesn't work for me on mobile, but all of Series 5 can be displayed.
    With these settings I wrote, it works for me
    Has anybody found a way to use the guest call feature as a trigger?
