Qubino Smart Sensor with Iskra BICOM432-40-WM1 on HC2 v4.600
I wanted to control my water heater, so I installed successfully Qubino Smart Sensor today along with IR switch BICOM432-40-WM1. I managed to pair it with HC2 v4.600 just fine and I now have all the readings just fine. I also managed to get the IR switch added and visible as a separate on/off device. However I cannot get it to work. No matter if I flip it on or off it doesn't actually end up changing the status of the switch and hence my water heater is always on.
Anyone else had this type of problem or managed to get this configuration working successfuly?
