Good evening everyone
I have created a simple scene to turn on the light when I open the door, it works well but a problem has arisen if the light is on via the switch when I open and close the door, the timer is activated that turns it off , how to avoid this thing?
thanks
Can’t see your Microsoft document. Can you add the code in the post as text?
    Hi
    i think i solved it, i used the devices as if they were a logic gate (and) and it seems to work.
