MCOHome MH7-EH doesn't work with heating panel HCL
I have a problem with MCOHome MH7-EH  and heating panel in HCL. I've set the device to heating and heat. Then I used this device in room as main temperature and termostat. But the heating panel will not update the termostat temperature, it always shows 20 degrees. However it work's when I set the temperature manually from devices.
Maybe I'm doing something wrong.
Thanks for help.
Thermostat gets updated by the heating panel after 2 hours since the last manual change.   And it works.
    Thanks, for reply. I will check it.
