Water level
Water level
I share my project (video), it may be that someone needs such a system.
If anyone needs help, just ask.
1- RGBW Controller 2
sensor
1-
As a beginner, I had the help of SmartHomeEddy
(thanks Eddy)
Edited by Vitor
  • Like 4
12 answers to this question
Great project @Vitor
Nice to see in the video the values instantly changing when moving the sensor ?
Nice project @Vitor!
Could you re-post the link to the sensor, link has 404 error?
    3 minutes ago, Tim__ said:
    Bom projeto @Vitor!
    Você poderia postar novamente o link para o sensor, o link tem o erro 404?
    sorry, I already changed the link ;)
    Veery interesting idea. The video is very informative. @Vitor Thank you
    could you please also share scene? Thank you
    Hello @SmartHomeEddy,
    I am trying to implement the same thing using UBS connecting sensor to IN1 analog input. When I use voltmeter to check voltage change, it works fine, but UBS does not show any change, it shows 0V continuously. I changed parameter 20 to 4, adjusted parameter 63 to 60 seconds ... but no help. I use HC3 with ZW3.
    Any ideas?
    Check this...
    Hm ... I checked it ... but not a single word how to make UBS display correct voltage. It looks that UBS is not refreshing the vale of IN1 analog entry at all
    I the above examples users use a RGBW controller, not a Universal Binary Sensor. Is a Universal Binary Sensor suitable for voltage measurements?
    @Goran111
    I saw now that you are trying to use a UBS device, and it is not possible.
    You have to use a Smart Implant to measure voltage.
    @RH_DreamboxI just switched to RGBW controller and it works just fine :-)
    Hi @Goran111,
    According to the manuals smart implant FGBS-222 can be used to measure analog input 0-10V :-)
