Forum1585646 0
Hi, I have mounted ID lock 150 with z-wave module. When I add the lock I get that the device is not configured, then I run a new configuration and this disappear.
Also comes up missing templates. The lock works when unlocking and locking the in HC2. The problem is when I run synchronization then the bare runs forwards, at the end a code slot comes up, then the bare automatic restarts without showing any changes. Never finished I have tried to remove the lock, then add it again but without difference. So only gets funksjons unlocked and locked. Does not get codes or parameters.
Anyone had this problem too?
/monthly_2020_11/image.png.43a6153ab379c3dbacf4d623c56217c4.png" />6 answers to this question
