Does this Trigger autostart a lua scene ?  Its supposed to be gateway start, which makes no sense
    type = "se-start",
    property = "start",
    operator = "==",
    value = true,
    isTrigger = true
4 answers to this question
No, se-start is a source trigger for scenes, i.e. the scene starts after the gateway has been started.
    But what is the gateway in this context ?  the HC, the network gateway ?
    if you asking about run any scenes when your HC3 is booting yes, you right
        type = "se-start",
        property = "start",
        operator = "==",
        value = true,
        isTrigger = true
    The HC3 is a SmartHome Gateway that is connected to the Internet via your router.
