MikeyTT 0
I've just bought a Qubino Thermostat 2 (
) to use as the controller for my underfloor heating in the kitchen. I've temporarily got a Qubino Relay 1 controlling the floor and that's working. I wanted the Thermostat 2 as it has built-in thermal cutoffs through the temperature sensor. HC2 has always needed rebooting every week or two, so I didn't want the floor running away temperature wise without being stopped.I've added the Thermostat2 into HC2, but there is no way of switching it on or off. I had thought maybe it's related to not using the HC2 heating panel as I do all my automation through Node Red, but even configuring that doesn't trigger the device. I've attached a screen grab of the main device and the 3 sub devices.
In the documentation (
) and the intro video (Please login or register to see this link.
) of the device it appears to have a way to switch on/off manually. Is there something I'm missing in HC2 that enables this type of device properly?Wiring wise I have the device wired almost exactly as the video did it, albeit my installation won't have a permanent switch, but I have one on temporarily while I'm testing.
6 answers to this question
