HC2 sometimes ignores variable
Hi!
I have a HC2 with the latest firmware. For over a year I had this problem with my system. The system sometimes ignores variables. For example: I have a scene changing brightness of the lights depending on Night, Day, Morning etc. But if variable is set to “Park ON” then the scene shouldn’t activate. Everything works fine when I restart the system, but after a few days, sometimes after a few hours the system starts to ignore the variable again. When I restart the system everything works fine again.. Does anybody else have the same problem?
Thanks!
%% properties
%% weather
%% events
%% globals
TimeOfDay
HomeButton
DSC_P1_ArmedStatus
if (
 ( fibaro:getGlobalValue("TimeOfDay") == "Day"  and  fibaro:getGlobalValue("HomeStatus") == "Home"  and  fibaro:getGlobalValue("SleepState") == "Awake"  and  fibaro:getGlobalValue("Park") == "OFF"  or  tonumber(fibaro:getGlobalValue("HomeButton")) == tonumber("255")  and  fibaro:getGlobalValue("TimeOfDay") == "Day"  or  tonumber(fibaro:getGlobalValue("DSC_P1_ArmedStatus")) == tonumber("4")  and  fibaro:getGlobalValue("TimeOfDay") == "Day" )
or
then
    fibaro:setGlobal("HomeNotis", "ON");
    fibaro:call(132, "open");
    fibaro:call(12, "setValue", "100");
    fibaro:call(40, "setValue", "100");
    fibaro:call(80, "setValue", "84");
    fibaro:call(62, "setValue", "100");
    fibaro:call(96, "setValue", "80");
    fibaro:call(91, "setValue", "25");
    fibaro:setGlobal("HomeButton", "0");
    fibaro:call(300, "setValue", "70");
    fibaro:call(282, "turnOn");
    fibaro:call(24, "turnOn");
    fibaro:call(10, "turnOn");
    fibaro:call(87, "turnOn");
    fibaro:call(286, "turnOn");
    fibaro:call(22, "turnOff");
    fibaro:call(295, "setValue", "10");
    fibaro:setGlobal("SleepState", "Awake");
    fibaro:setGlobal("AlarmClockDays1", "9999");
    fibaro:setGlobal("AlarmClockDays2", "9999");
    fibaro:setGlobal("Park", "OFF");
    fibaro:setGlobal("BlindsStatus", "Open ");
    fibaro:setGlobal("HomeStatus", "Home");
    fibaro:call(402, "turnOff");
    fibaro:call(313, "setValue", "35");
Edited by JoeChew
not sure what a bug on the Fibaro side.
just read all values in "vars"
print vaues
if var1 and var2 and var3...
and check logs when you find what somtimes occured.
    Fibaro ignores all variables. I made new ones, tried different scenes. I also deleted triggers, but scene is triggered even though triggers are deleted.
    After a reboot Fibaro reacts normal to variable rules in the scenes. I guess it's a bug in the system. Can anybody from Fibaro comment on this?
    as far as I remeber this bug has a 2y voyage.
