Possibility to integrate Tydom Delta Dore 1.0 to Fibaro (HC3)
Hi there,
My garagedoor works with the Tydom 1.0 hub to operate the garedoor from my mobile device. I can open and close the door, but I can also see the the status of the door, it can be "open", "closed" or "partly open".
Is it possible to integrate this system with my fibaro (HC3) system? So that I can make scenes that open/closes the door after x-period, open it when motion is detected or to turn off/on lights when the door opens or closes? Etc. etc.
For more info:
Thanks in advance!
according to
popabaly, yes, it can be integrated with HC3
    Thanks, there is a lot of docs and scripts there.
    Is there an "easy" tutorial how to integrate it?
    You are asking about Possibility to integrate my answer yes, it possible.
    but I am not said what somebody did it. It's should be write from the scratch.
    so,
    1) start learing LUA
    2) who to write QA (search jgab topic)
    3) and finally how to work with web sockets in HC3
