Hello Everyone, I am working on some projects that seeks help in finding the appropriate tutorials for lua programming. I want to learn lua right from the basics and take it step by step. Where can I get these tutorials?
Lua basic programming
    -Lua tutorial
      Only the basic part. Skip Modules, Metatables, Coroutines, File I/O, Error Handling
    - Lua 5.3 reference - Standard Library
      Look at string, table and math library functions
Download
that is a free (and good) Lua IDE to practice Lua coding
Fibaro Scene and QA coding
    Fibaro provides a lot of Lua functions to interactive with the HC2 and HC3 platforms.
    - HC2 -
    - HC2 -
    - HC3 Scenes -
    - HC3 QuickApps -
Engage in this forum, look at users posts and example code (ex. the
Look at best practices like how to store configuration data in Fibaro global variables (
...and how to work with timers (
Optional, install my
that run in ZeroBrane studio (and VS) and start coding...
  • Like 3
These are enough tutorial list which are curated by the community member but still I would suggest you to go to
and check the best one for you which are curated by the lua experts.
  • 2 months later...
Dear All!
Is anybody aware that if there is a LUA coding best practices or something like that?
I could have read in a lot of streams that the bad coding could cause for example high memory or CPU consumption.
What could be the best considerations we should take into account to do nice, efficent coding in LUA (i.e. avoid CPU consuming function like DELAY, etc.)?
Thank you!
5 minutes ago, krizso said:
Dear All!
Thank you!
read the posts of @jgab
Well, there is efficient coding in Lua that's... that could be much better if Fibaro let us have more of standard  Lua (coroutines, metatables)
Then there is efficient coding on the HC3... that tends to vary with FW release (avoiding bugs du jour etc) ;-)
Then there is nice coding :-)
