Not regulating at all - I think I tried everything
Janusz
Hi
Updated to 4.7, reset to factory settings, deleted and added again - still nothing. close to 3 deg difference and HC is closed. I am not using Plug-in (Thermostat & heating) - never did and as before - other rooms are working. Same situation in 3 rooms - those without external temp. sensor. Fot the rooms with external sensor system is regulating. I added an offset of temperature of 3 deg. (by the way - why put offset range there from -100 to 100?)
I am running it with HC lite. Other rooms are operating - can you help with list of possible things to check? I ran out of options.
Janusz
