Need help with HC2 Heating Script to HC3 Script conversion
Hi All,
I am using my HC2 to control my central heating. It is a Lua scene I found on the forum and adapted it for my needs. And that works great. :)
But now I have bought a HC3 and started looking into the Lua part, and found it is completely changed. And my programming skills are not good enough to see what needs to be changed in the current Lua Script from the HC2.
Who can help me to convert the basics of the scrip t?
So I can get it working on my HC3, and I can understand the differences.
Thnx
13 answers to this question
...spaghetti code
    @10der
    I know, but it works.
    I have no idea on how to get it working in HC3.
    Can you help me break it up in parts, so I can rebuild it in HC3?
    Edited by rwijbenga
    not sure
    i hate such code
    i never working with such code.
    i am to much expensive (rate $50 per hour) I don't think about what worth a shot.
    Edited by 10der
    try to understand all alone.
    thank you!
    Edited by 10der
    That is structure ?
    Goodday all,
    @10der, I modified your code a little so it runs on HC3.
    I also added manual override and the build in open window check of the Fibaro heat controller.
    Maybe when I have the rest of the house moved from the HC2 to the HC3 I'll go back to window sensors (to little time to really play with HA).
    For now I have the code in a scene that runs every minute, maybe in the future I'll try to make a QA out of it.
    At first I tried the Fibaro heat activator plugin, but that works very poorly, think Fibaro has shares in my local gas company... Very glad I found your code!
    Sorry I turned your code into spaghetti again :).  I am no coder by very very far.
    P.s. I use Fibaro heat controllers, not sure if this works for other brand's heat controllers.
    P.p.s. I use a hometable, if anyone who's interested in this remove the following line:
    The Scene:
    Jim
    Same here, a lot of glitches in the heat activator.
    I also use a modified code from @10der
    Welcome guys, but it’s not my code ;) just all credits to topic starter ;)
    Ah thanks @10der for clearing that up.
    Thanks @rwijbenga for the code in the first palce!
    Jim
    I am just rewrite code ;)
    And that was/ is very useful for me at least :D
    Also for me ?
    Which part of the code belongs to be in the Declarations / Actions? @10der @jimicr
    I tried to break it up myself, but have issues with saving the scene.
