marlo 2
I'm new to the Fibaro system but I'm quite disappointed. The problem is how the Heat Controller works. I have installed this heating system on one floor of the house and I also bought it on the other floor but I don't know if I will install it for these problems. I'll probably sell it because it's a disaster. I expected better software processing from these systems. Fibaro presents itself as a top on the smart market, but my disappointment is great. With such a large financial investment.
Issue # 1:
When I set all heads to OFF, sometimes the Heat Activator does not turn off because some heads still make a request for heating even when it is turned off. Check image:
Issue # 2:
When I return all the heads to the weekly plan, sometimes some head does not take over the temperature from the weekly plan but sets a different temperature I don't know how. I will solve this only by manually setting the given head to a certain temperature and then returning it and then it will take over the temperature from the weekly schedule.
Issue # 3:
The hysteresis on these heads works strangely.
When I have set the temperature to 21 ° C, the hysteresis is about 2 to 3 ° C, which means that when it reaches the desired temperature, then it regulates only in the range of 19 to 20 ° C and does not reach the desired temperature.
Issue # 4:
The graph of temperature and setpoint temperature shows values that I do not understand.
When I have set the temperature to 22 ° C, the request is drawn in a special way and shows the desired temperature of 22.5 ° C. Even when the head is off, the setpoint is displayed in the graph as a temperature that is not even in the weekly schedule.
One more question? Does anyone know what this graph is and why it can't be displayed?
27 answers to this question
