Lights on with different switches
I have on my bedroom
Light 1 with single switch 1 and wallswitch 1
Light 2 with single switch 2 and wallswitch 2
Single switch 3 with wallswitch 3
I want if i push wallswitch 3 lights  1 en 2 on or off. But if i use wallswitch 1 Light 1 on or off and if i push wallswitch 2 Light 2 on or off.
Lights 1 and 2 are the lights left and right next to the bed the same als switch 1 and 2. The wallswitch 3 is next to the door.
Edited by Reinhold
4 answers to this question
@Reinhold I had to read it more than once ?
I think you want to toggle the lights, but what if light 1 is on and light two is off. Switch 3 will toggle light 1 off and light 2 on ?
It sound more like you want to switch both lights off with switch 3 if one of the lights is on?
And you want to switch both lights on with switch 3 if both of the lights are off?
Edited by SmartHomeEddy
    Yes i want to toggle the lights. And if light 1 is on en light 2 is off then if i use switch 3 then both light must off.
    %% properties
    310 value
    %% weather
    %% events
    %% globals
    if (fibaro:countScenes()>1) then fibaro:abort()
    fibaro:debug("2de scene word gestopt")
    local startSource = fibaro:getSourceTrigger()
    local switch3= 310 -- single switch
    local light1 = 168 -- single switch
    local light2= 105 -- single switch
    if tonumber(fibaro:getValue(switch3, "value")) >= 0 then
      if tonumber(fibaro:getValue(light1, "value")) == 0
        and
         tonumber(fibaro:getValue(light2, "value")) == 0 then
        fibaro:call(light1, "turnOn")
          fibaro:call(light2, "turnOn")
       else
        fibaro:call(light1, "turnOff")
          fibaro:call(light2, "turnOff")
    Edited by Reinhold
    looks like this should work, does it?
    This works, but if i turn off light 1 with switch 1 and i toggle then switch 3 the light 1 turn on and 2 goes off.
    Edited by Reinhold
