sithmein 0
I have been using the FGS-223 for month without issues. The switch is in a wallbox on the ground floor, the Z-Wave receiver in the cellar, air distance about 4 m. About a week ago the switched stopped responding while other devices continued to work. I tried resetting everything, removing and re-adding, nothing worked. Until I moved the receiver on the same floor within around 1m distance of the switch. Then it suddenly worked again. However, already three meters distance without any objects in between break communication again. My suspicion is that the antenna stopped working. Has anyone ever experienced a similar issue? I guess the only way to fix this is replace the switch?
7 answers to this question
