Heating plan, room / radiator thermostat
Hi there
Is there a sample software for the configuration of the heating plan, room thermostat and radiator thermostat?
I would like to enter the desired subject matter in the time plan.
Then the room thermostat should be used as the target temperature.
That in turn should control the radiator thermostat 1-4 pieces.
Gateway = HC3
Software = LUA
Room thermostat = Devolo
Radiator thermostat = Danfoss
Greetings Frank
Hi, sorry, I don't really have an answer, but I'm looking for exactly the same thing, I'm happy I'm not alone. I was using Jeedom until recently where this was easily possible with a built-in plugin.
I'm actually looking to implement two setups, one exactly like yours and another one without the wall thermostat, just the radiator thermostat. However, in Fibaro HC3 the Devolo Radiator Thermostat doesn't seem to be fully supported, or at least I don't find a way of making it appear as a thermostat, only as HVAC and sensor temperature, but then it's not possible to modify the set-point temperature from the HC3 interface.
Also, after installing it, I got a notification that there is no template in HC3 for it and I was asked to download the device data and send it to Fibaro support in order to help with the implmentation of the template. However, this device has been on the market for quite sometime, if a template is not available by now, I doubt, it will be. I'm considering to produce a custom template based on the information I still have in the Jeedom system and write a QuickApp.
Please let me know if you find a solution.
Cheers.
