HC2 scene POST using LUA to Home Assistant
HI, i try to solve lack of remotes integration from fibaro to Home assistant
i want: - double press walli switch , then run scene on fibaro with POST HTTP to Home assistant to do something.
for now i try to create virtul device with lua script to connect to HA. i have authentication issue. I created user fibaro with pass fibaro
i based on this solution:
but i want to have authorization (i dont even know how to connect to HA with no authorisation)
as i see documentation i need bearer and token   - i dont know how to write it in LUA
for now i stopped here
Quote
local switch = "switch.netvox_plug_switch"
local thisdevice = fibaro:getSelfId()
local ip = fibaro:getValue(thisdevice, 'IPAddress')
local port = fibaro:getValue(thisdevice, 'TCPPort')
--local user = "fibaro";
--local pwd = "fibaro";
local Authorization = "eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJpc3MiOiI3NzFiMGZjMDc3OWI0Y2E5YjA4ZWQ0OGYzNGEyM2ZkMSIsImlhdCI6MTYwODI1Mjc4OCwiZXhwIjoxOTIzNjEyNzg4fQ.NwdOALjPCN6l_ewhCvRcsW3O6SuLg8qck2-rHjpz36o"
local httpSession = Net.FHttp(ip, port);
jsonTable = { entity_id = switch }
jsonString = json.encode(jsonTable)
response, status, errorCode = httpSession:POST("/api/services/switch/turn_on", jsonString, Authorization )
