run scene based on date variable
Hi all, would really appreciate any help which can be provided.
Using HC3, I want to store a date as a variable and then at sunset of the following day run a scene.
Was thinking of storing the date as global variable and then I need to run a scene which adds 1 day to the stored date if it matches then run scene.
Global Variable Name Is HoildayDate = "11/20/20"
I am stuck on how to manipulate the stored value to be able to trigger the scene.
 Thank you
    1 hour ago, Bodyart said:
    moved it in to a qa and it works perfectly thank you, is there a way of running it from a scene instead of a quickapp?
    Why would you like it to run from a scene?!?
    hmm as i will be running it on a timer in a scene and thought it would be neater to keep it all in one scene
    this has stopped working have i got a typo somewhere?
    function QuickApp:checkYomTov()
        http =net.HTTPClient()
        local today = os.time() --+ (86400*94) -- used to check for forward dates for testing purposes
        local year = os.date("%Y",today)
        local month = os.date("%m",today)
        local day = os.date("%d",today)
        local checkdate = year.."-"..month.."-"..day
        local tomorrow = today + 86400
        local yearTomorrow = os.date("%Y",tomorrow)
        local monthTomorrow = os.date("%m",tomorrow)
        local dayTomorrow = os.date("%d",tomorrow)
        local checkdateTomorrow = yearTomorrow.."-"..monthTomorrow.."-"..dayTomorrow
        local httpstring = "https://www.hebcal.com/hebcal?v=1&cfg=json&maj=on&geonameid=2643123"
        local address  = httpstring.."&year="..year.."&month="..month
        print (address)
        http:request(address,{options={headers={Accept="application/json"},method='GET'},
                success = function(response)
                    local cal=json.decode(response.data)
                    for i=1,#cal.items do
                        if cal.items[i].date==checkdate then
                            if cal.items[i].yomtov==nil then cal.items[i].yomtov=false end
                            print (cal.items[i].yomtov)
                            if cal.items[i].yomtov==true then
                                print('Today is Yom Tov: ',cal.items[i].date)
                            else
                                print('Today is NOT Yom Tov: ',cal.items[i].date)
                            --print('Yomtov is',tostring(cal.items[i].yomtov))
                            --if cal.items[i].yomtov==nil then cal.items[i].yomtov=false end
                            --print('Yomtov is today: ',cal.items[i].date)
                        elseif cal.items[i].date==checkdateTomorrow then
                                print('Tomorrow is Yom Tov: ',cal.items[i].date)
                            else
                                print('Tomorrow is NOT Yom Tov: ',cal.items[i].date)
                end,
                error = function(error)
                    fibaro.debug("error: "..json.encode(error))
    function QuickApp:onInit()
        self:debug("onInit")
        self:checkYomTov()
    The code works if it cal.items[i].yomtov==true
    however i cant get it to work if it is not true can you please advise?
    Hi @Jay Ess,
    insert before working with the value of  cal.items[i].yomtov
    simple test:
    Edited by Bodyart
    have a weird sitution going on here i am using the following code to pick up hebrew dats by json,
    the line print ("A") runs before the function whihc gets callled higher up, can anyone please advise what is going wrong?
    yomTovToday = ""
    yomTovTomorrow = ""
    adjustYomTovName = ""
    hR = ""
    ytR = "false"
    ecR = "false"
    erevchagVariableName ="erevChag"
    yomtovVariableName = "yomtov"
    getErevChagValue = fibaro.getGlobalVariable(erevchagVariableName)
    getYomTovValue = fibaro.getGlobalVariable(yomtovVariableName)
    getHebrewDateValue = fibaro.getGlobalVariable("hebrewdate")
        --print ("Y "..getYomTovValue.." E "..getErevChagValue.." H "..getHebrewDateValue)
        local http =net.HTTPClient()
        local testyomtovdate = fibaro.getGlobalVariable("testYomTovDate")
        local today
        --adjust the day for sunset ie. after sunset it is the next day
        local sunset = fibaro.getValue(1"sunsetHour")
        local currentTime =os.date("%H:%M")
        if currentTime >= sunset then
            today = os.time() + 86400 + (86400*tonumber(testyomtovdate))
        else
            today = os.time() + (86400*tonumber(testyomtovdate))
        local httpstring = "https://www.hebcal.com/hebcal?v=1&cfg=json&maj=on&geonameid=2643123&d=on"
        ytR = "false"
        ecR = "false"
        yomTovToday = ""
        yomTovTomorrow = ""
        print ("1: "..address)
        print ("2: "..checkdate)
                    for i=1,#cal.items
                        do
                            if cal.items[i].date==checkdate and cal.items[i].category=="hebdate" then
                                --Put Hebrew Date In Variable if it is not already in
                                hR = tostring(cal.items[i].title_orig)
                                if getHebrewDateValue ~= hR then
                                    fibaro.setGlobalVariable("hebrewdate", hR)
                            --Check if today is Yom Tov
                            if cal.items[i].date==checkdate and cal.items[i].category=="holiday" then
                                    ytR="true"
                                yomTovToday = tostring(cal.items[i].title)
                            --Check if tomorrow is Yom Tov
                            if cal.items[i].date==checkdateTomorrow and cal.items[i].yomtov~=nil then
                                ecR="true"
                                yomTovTomorrow = tostring(cal.items[i].title)
                    print (ecR)
                    self:setYomTovVariables()
                end,
        print ("a")
        --self:setYomTovVariables()
        self:updateView(
            "lblStatus""text""Last Updated: "..os.date("%d/%m/%Y-%H:%M").."<br>Hebrew Date: "..fibaro.getGlobalVariable("hebrewdate").."<br>YomTov: "..fibaro.getGlobalVariable("yomtov").."<br>Erev Chag: "..fibaro.getGlobalVariable("erevChag").."<br>Pesach: "..fibaro.getGlobalVariable("pesach").."<br>Yom Tov Name: "..fibaro.getGlobalVariable("yomtovname")
    function QuickApp:setYomTovVariables()
        print ("Yom Tov Today: ytR: "..ytR)
        print ("Yom Tov Tomorrow: ecR: "..ecR)
        print ("Yom Tov Today: "..yomTovToday)
        print ("Yom Tov Tomorrow: "..yomTovTomorrow)
        if ytR == "false" then
            --if yomTov == "true" then
                fibaro.setGlobalVariable(yomtovVariableName, "false")
            --end
            if ecR =="false" then
                --if erevChag == "true" then
                    fibaro.setGlobalVariable(erevchagVariableName, "false")
                --end
            else
                --if erevChag == "false" then
                    fibaro.setGlobalVariable(erevchagVariableName, "true")
                --end
        else
            --if yomTov == "false" then
                fibaro.setGlobalVariable(yomtovVariableName, "true")
            --end
            --end
        self:setYomTovName()
    function QuickApp:setYomTovName()
        if yomTovToday ~= "" then
            adjustYomTovName = yomTovToday
        else
            if yomTovTomorrow ~= "" then
                adjustYomTovName = yomTovTomorrow
        print ("Yom Tov Name: "..adjustYomTovName)
        if adjustYomTovName ~= "" then
            if string.match(adjustYomTovName,"Pesach"then
                adjustYomTovName="Pesach"
            elseif string.match(adjustYomTovName,"Shavuot"then
                adjustYomTovName="Shavuot"
            elseif string.match(adjustYomTovName,"Rosh"then
                adjustYomTovName="Rosh Hashana"
            elseif string.match(adjustYomTovName,"Yom"then
                adjustYomTovName="Yom Kippur"
            elseif string.match(adjustYomTovName,"Sukkot"then
                adjustYomTovName="Sukkot"
            elseif string.match(adjustYomTovName,"Shmini"then
                adjustYomTovName="Shmini Atzeret"
            elseif string.match(adjustYomTovName,"Simchat"then
                adjustYomTovName="Simchat Torah"
        local YomTovName = fibaro.getGlobalVariable("yomtovname")
        print ("Variable Yom Tov Name: "..YomTovName)
        if YomTovName ~= adjustYomTovName then
            fibaro.setGlobalVariable("yomtovname", adjustYomTovName)
        local PesachVariable = fibaro.getGlobalVariable("pesach")
        local SukkotValriable = fibaro.getGlobalVariable("sukkot")
        if adjustYomTovName == "" then
            if PesachVariable=="true" then
                fibaro.setGlobalVariable("pesach""false")
            if SukkotValriable=="true" then
                fibaro.setGlobalVariable("sukkot""false")
        else
            if adjustYomTovName=="Pesach" then
                if PesachVariable == "false" then
                    fibaro.setGlobalVariable("pesach""true")
            if adjustYomTovName=="Sukkot" then
                if SukkotValriable=="false" then
                    fibaro.setGlobalVariable("sukkot""true")
        print("END")
        self:checkYomTov()
        setInterval(
            function()
                self:checkYomTov()
            end,
            1000 * 601
    Short answer, net.HTTPClient() is asynchronous.
    See
