Hi to the beautifull forum.
I got fibaro home center some years ago in order to use it as my main smart home application for all things at home. finally most most controllers are up now and working. (walli roller shutters and things like that).
All things are working perfectly synced. But i hav a problem that i don't know how to solve and i really need your help because i can find an appropriate solution to the problem.
i Hav a Solar water heater model (
and at the same time i hav a water heater 80 ltrs powerd from the main panel of my home. (i use this one when there is no sun because it's only 80 ltrs and it heats fast)
i use this plug in order to make the change between the solar and the normal water heater
The main thing that i want to do is.... i want when the solar has hot water that things above to switch to solar and when it hasnt to return to the other heater.
I would appreciate if someone has a solution at this because i don't know that to buy in order to:
1) insert  the temperature of the solar water heater to Fibaro
2)what to buy in order to make the Valve change automatic direction
Thank you for your time Take care all
