Reading gas data SUPLA
Hello, can anyone help me to read the item data from the json table. When debugging, I see data but
I cannot display them in the label.
Json answer looks like this:
{"connected":true,"totalCost":11301.16,"pricePerUnit":1.3,"impulsesPerUnit":10,"counter":86932,"calculatedValue":8693.2,"currency":"PLN","unit":"m\u00b3"}
-- Energy meter type have no actions to handle
-- To update energy consumption, update property "value" and "energy" with the same floating point number
-- Eg.
-- self:updateProperty("value", 226.137)
-- self:updateProperty("energy", 226.137)
-- To update controls you can use method self:updateView(<component ID>, <component property>, <desired value>). Eg:
-- self:updateView("slider", "value", "55")
-- self:updateView("button1", "text", "MUTE")
-- self:updateView("label", "text", "TURNED ON")
-- This is QuickApp inital method. It is called right after your QuickApp starts (after each save or on gateway startup).
-- Here you can set some default values, setup http connection or get QuickApp variables.
-- To learn more, please visit: https://manuals.fibaro.com/
   function QuickApp:onInit()
    self.http = net.HTTPClient({timeout=3000})
    local address = 'https://svr24.supla.org/direct/931/ZjzzNhjATmYVdN/read'
    self.http:request(address, {
        options={
            headers = {
                Accept = "application/json"
            method = 'GET'
        success = function(response)
            self:debug("response status:", response.status)
            self:debug("headers:", response.headers["Content-Type"])
            local data = json.decode(response.data)
            local apiResult = json.encode(response.data)
            apiResult = apiResult:gsub("%[", "")
            apiResult = apiResult:gsub("%]", "")
            self:debug("apiResult",apiResult)
            local jsonTable = json.decode(apiResult)
            self:debug("jsonTable",jsonTable)
            -- Get the values
            local gaz_consumption = string.format("",jsonTable.calculatedValue)
            self:debug("Aktualne zużycie GAZU:",gaz_consumption.." m3")
        -- Update the labels
        self:updateView("label", "text", "Aktualne zużycie GAZU: " ..gaz_consumption .." m3")
        end,
        error = function(error)
            self:debug('error: ' .. json.encode(error))
Edited by ptekien
4 answers to this question
function dump(o)
    if type(o) == 'table' then
       local s = '{ '
       for k,v in pairs(o) do
          if type(k) ~= 'number' then k = '"'..k..'"' end
          s = s .. '['..k..'] = ' .. dump(v) .. ','
       return s .. '} '
    else
       return tostring(o)
local gopa = '{"connected":true,"totalCost":11301.16,"pricePerUnit":1.3,"impulsesPerUnit":10,"counter":86932,"calculatedValue":8693.2,"currency":"PLN","unit":"m\\u00b3"}';
print(dump(json.decode(gopa)))
local blabla = json.decode(gopa)
print(blabla["calculatedValue"])
8693.2
    Thanks for your help @10der. Below, the entire code, if someone would like to change it, in the link variable we provide a direct link from the SUPLA cloud.
    -- Eg.
        local address = self:getVariable("link")
            options={
                headers = {
                method = 'GET'
                function dump(o)
           local s = '{ '
           for k,in pairs(o) do
           return s .. '} '
        else
           return tostring(o)
    local gopa = jsonTable;
    local decode = json.decode(gopa)
    --print("Aktualne zużycie gazu:",decode["calculatedValue"]," m3")
                -- Get the values
                local gaz_consumption = string.format(decode["calculatedValue"])
                --self:debug("Aktualne zużycie:",gaz_consumption.." m3")
            self:updateView("label1", "text", "Aktualne zużycie Gazu:  ".. gaz_consumption.."  m3")
            end,
    @10der Maybe you could help me read the data from this answer:
    {"connected":true,"support":40959,"currency":"PLN","pricePerUnit":0.2,"totalCost":1024.65,"phases":[{"number":1,"frequency":50,"voltage":242.44,"current":0.749,"powerActive":95.82806,"powerReactive":-76.06786,"powerApparent":178.04242,"powerFactor":0.544,"phaseAngle":141.7,"totalForwardActiveEnergy":1203.26096,"totalReverseActiveEnergy":0,"totalForwardReactiveEnergy":0.8014,"totalReverseReactiveEnergy":526.2808},{"number":2,"frequency":50,"voltage":240.92,"current":1.499,"powerActive":261.24704,"powerReactive":-157.6632,"powerApparent":354.11944,"powerFactor":0.734,"phaseAngle":149.4,"totalForwardActiveEnergy":1760.55192,"totalReverseActiveEnergy":4.0e-5,"totalForwardReactiveEnergy":88.34716,"totalReverseReactiveEnergy":409.14398},{"number":3,"frequency":50,"voltage":240.99,"current":2.415,"powerActive":484.21536,"powerReactive":-238.9743,"powerApparent":570.62374,"powerFactor":0.848,"phaseAngle":153.7,"totalForwardActiveEnergy":2159.44256,"totalReverseActiveEnergy":0,"totalForwardReactiveEnergy":85.11984,"totalReverseReactiveEnergy":1010.6825}]}
    I would like to read the voltage and power from phases 1, 2, 3 and the total cost
    witam.
    ctrl+C
    ctrl+V
    [PROCESS]
    [] - to jest array (aaa[1] aaa[2] ...)
    uczyс sie...
