Blinds not visible in Google Assistant...
kgeusens
Hi there,
I recently started experimenting with the Fibaro integration into GA (Google Assistant) and so far I'm very happy with it, with one exception:
I have 2 roller shutters in my setup, and no matter what I try, they do not show up in GA. From what I can read in the forum, blinds/shutters are now supported, so I'm hoping to find some help here :)
I already tried upgrading my HC2 to the latest version (4.60), removed and re-added the fibaro integration into GA, but still nothing shows up.
The shutter controller is from Fibaro, but I can not determine the exact type from the configuration window (see screen shot)
Did I miss something?
/Koen
I am sorry, I don't know HC2, but maybe this hint will help you: On HC3 I had to setup Role as Blind with positioning.
/monthly_2021_01/2021-01-03_11-14-01.png.b93a426304d6181ed9e3350b26fe15af.png" />
Hey All,
I bought a new HC2 and set my all devices properly.while im try to connect my hc2 to google home assistant i encountered on the same problem with the blinds.
Does anyone solve this problem?
Thanks,
Raz.
