If movement burn lamp
Hi tried to made a scene, but after many tries, I didn't succeeded.
Problem:
I have a Fibaro  Sensor and and Lamp dimmer in the hall. I made a simple scene, if Sensor detect movement automatically the lamps starts to burn to X seconds.
But I like to make to real time. If movements, the lamp has to burn for X seconds, but for new movements the counter has to be reset to X seconds.
So If people are moving in the hall, the lamp should be switch on for X second. So in fact if movement has been countered the the lamp burn counter should be reset.
I tried to create to made events, if movement than "Hall_movement_on", but can't make it works real time.
Request:
Who has experience making (lua) scene, with hc3 and this request.
Hope you help me out.
thx
Edited by Tikilauda
mistake in sentence
12 answers to this question
@Tikilauda Which homecenter are you on?
Edited by SmartHomeEddy
Hi @SmartHomeEddy :-D
    indeed HC3
    There are several solution. This is one of them:
    Thx Eddy,
    I have a look to the code as well, hope it's feasible for my solution as well.
    Best regards
    Frank
    It will work
    hi,
    how can I do it in HC2? :)
    Replace fibaro. with fibaro: and pray ?
    To make it very simple
    Change settings to pir: safe time is 60 sec (set the time that you want the light to lit)
    2 scenes:
    if pir is breached, light on
    if pir is safe: light off
    Edited by akatar
    I installed the lua code. It's works fine, but intermittent the light goes on, without any movement in the hall, but with ërror in the log.
    Any idea what I did wrong.
    [29.12.2020] [05:04:56] [ERROR] [SCENE83]:
    [29.12.2020] [05:04:56] [DEBUG] [HAL LIGHT]: Turning on (ID 39) Hal licht for 60 seconds
    [29.12.2020] [05:05:01] [DEBUG] [HAL LIGHT]: Counting up safeTime 5 to maxTime 60
    [29.12.2020] [05:05:01] [DEBUG] [HAL LIGHT]: Reset by Motion sensor 23 PIR-01-Hal
    [29.12.2020] [05:05:06] [DEBUG] [HAL LIGHT]: Counting up safeTime 5 to maxTime 60
    [29.12.2020] [05:05:11] [DEBUG] [HAL LIGHT]: Counting up safeTime 10 to maxTime 60
    [29.12.2020] [05:05:16] [DEBUG] [HAL LIGHT]: Counting up safeTime 15 to maxTime 60
    [29.12.2020] [05:05:21] [DEBUG] [HAL LIGHT]: Counting up safeTime 20 to maxTime 60
    [29.12.2020] [05:05:26] [DEBUG] [HAL LIGHT]: Counting up safeTime 25 to maxTime 60
    [29.12.2020] [05:05:31] [DEBUG] [HAL LIGHT]: Counting up safeTime 30 to maxTime 60
    [29.12.2020] [05:05:36] [DEBUG] [HAL LIGHT]: Counting up safeTime 35 to maxTime 60
    [29.12.2020] [05:05:41] [DEBUG] [HAL LIGHT]: Counting up safeTime 40 to maxTime 60
    [29.12.2020] [05:05:46] [DEBUG] [HAL LIGHT]: Counting up safeTime 45 to maxTime 60
    [29.12.2020] [05:05:51] [DEBUG] [HAL LIGHT]: Counting up safeTime 50 to maxTime 60
    [29.12.2020] [05:05:56] [DEBUG] [HAL LIGHT]: Counting up safeTime 55 to maxTime 60
    [29.12.2020] [05:06:01] [DEBUG] [HAL LIGHT]: Counting up safeTime 60 to maxTime 60
    [29.12.2020] [05:06:01] [DEBUG] [HAL LIGHT]: Turning off 39 Hal licht
    Conditions:
     conditions = { {
          id = 23,
          isTrigger = true,
          operator = "==",
          property = "value",
          type = "device",
          value = true
          isTrigger = true,
          operator = "==",
          property = "schemer",
          type = "global-variable",
          value = "Ja"
      operator = "all"
    Action:
    -- This scene turns on one or more lights:
    --    turns off the lights after a certain time (maxTime),
    --    unless there is motion from one or more Motion sensors
    -- Please enter the right ID's (if more than one, seperate by ",") and the prefered maxTime for the lights to stay on
    local light = {39-- ID's of the lights to turn on
    local motion = {23-- ID's of the Motion sensors to check if they are breached
    local maxTime = 1*60  -- Maximum time the sensor should be safe before turning off (n*60 where n is minutes)
    local sleepTime = 5 -- Time in seconds between each check of the Motion sensor (default = 5)
    local debug_TAG = "Hal light" -- Tag for the debug messages
    -- Below here no changes are necessary
    for i in pairs(light) do -- Turn on the lights
      fibaro.debug(debug_TAG,"Turning on (ID " ..light[i] ..") " ..fibaro.getName(light[i]) .." for " ..maxTime .." seconds")
      fibaro.call(light[i],"turnOn")
    local safeTime = 0
    while safeTime < maxTime do -- Loop until maxTime is reached
      fibaro.sleep(sleepTime*1000)
      safeTime=safeTime+sleepTime
      fibaro.debug(debug_TAG,"Counting up safeTime " ..safeTime .." to maxTime " ..maxTime)
      for i in pairs(motion) do
        if fibaro.getValue(motion[i],"value"then -- Check if Motion sensors are breached
           fibaro.debug(debug_TAG,"Reset by Motion sensor " ..motion[i] .." " ..fibaro.getName(motion[i]))
           safeTime = 0 -- Reset safeTime to zero
    for i in pairs(light) do -- Counted down to maxTime, turn off the lights
      fibaro.debug(debug_TAG, "Turning off " ..light[i] .." " ..fibaro.getName(light[i]))
      fibaro.call(light[i],"turnOff"
    Help is appreciated.
    6 minutes ago, Tikilauda said:
     isTrigger = true,
          operator = "==",
          value = "Ja"
    Your Global variable should not be a trigger, only a condition: isTrigger = false
    Thank you so much! Really appreciated Eddy.
