Martin_N 154
Hi all,
I don't know if anyone has dealt with this issue, which I have been thinking about for a long time.
How to connect two / three switches to one SmartImplant input ...
We have 2 options.
1) tie about it in bin2dec mode.
i1 = 0, i2 = 0 => 00 = state 0 all off
i1 = 1, i2 = 0 => 01 = state 1 on
i1 = 0, i2 = 1 => 10 = state 2 on
i1 = 1, i2 = 1 => 11 = state 3 on
However, this has a problem in that it cannot be used well enough for ordinary switches, but rather on some rotary selector, which can switch both inputs at once.
2)
I would use the input in analog mode.
Then equip the individual switches with resistors (parallel to the NO contact), which will make a voltage divider.
Simplified by using for example 1x kohm + (s1) 2kohm + (s2) 10kohm it will solve 3 states on one input:
1) s1 off, s2 off = 13kohm
2) s1 on, s2 off = 11kohm
3) s1 off, s2 on = 3kohm
4) s1 on, s2 on = 1kohm
From the above, you can then distinguish the correct states .. a suitable choice of resistance can add a third switch, but it's even more complicated ....
Fibaro states the input resolution of up to 100 samples.
Did anyone do something similar?
eM.
9 answers to this question
