How to read Temperatuur settings from ID 1
Good afternoon,
Is there anybody here that can advice me on how to read the value of ID 1.
ID one is automatically generated by the system when creating temperature zones.
However reading out like
TempTarget = fibaro.getValue(1"value")
Does not work.
10 answers to this question
1 hour ago, Tiger1958 said:
Good afternoon,
Does not work.
http://192.168.1.36/swagger?urls.primaryName=panels%2Fclimate
where 192.168.1.36 is your HC3 ip address
    Hi 10der and happy new Year,
    Thank you for your reply.
    So far so good, however how to implement this in my case (scene)?
     Below scene works perfect as long I fill in a fixed value (eg 21) at TempTarget.
    I am sorry sir
    I do not know what deviceId meant cuz deviceId is HC3
    so, you trying to ask HC3 self value? Lol
    never know before what HC3 has own value
    is is value is temperature or switch state?! Lol
    if you still do not know what I mean
    please call
    http://192.168.1.36/api/devices/1
    where 192.168.1.36 is your IP address of hc3
    this is deviceId = 1
    HI 10der,
    I followed your advice as per below print.
    However I do not understand how to implement this in my scene.
    The only thing I want is to read the value of the set Temperature of ID 1, which is generated by the climate zone "Groundfloor" Schedule.
    3 hours ago, 10der said:
    cuz deviceId is HC3
    Is the ID 1 the HC3 and thus the temperature the measurement of the weather station you configured in the settings for the HC3 ?
    no!
    /monthly_2021_01/image.png.5fa29c8a23dc70938ba02f2f2f1732c6.png" />
    Not to worry, as I found my answer with below post.
    Very simple, however with the lack of proper documentation on Fibaro HC3 use of LUA it took me long to find out
    Thank you all for your help anyhow
    not sure, cuz you are asking about heating Zone.
    ths sample  for thermostat
    Edited by 10der
    @Tiger1958 if you really wnat to know the current heating value for concrete zone you should do a some magic
    /monthly_2021_01/image.png.0d8fc1a41a9580628d5b0259198ce05f.png" />
    Edited by 10der
