Hi @jgab
Happy newyear ☄️??
I have integrated my Velux window with a Velux KLF050
Here is a nice picture
I will use the
combined with
/monthly_2021_01/image.png.0aceda4fb95a973ee407ff5399d8da5c.png" />
For the 2 - Windows Open for 15min. I still need to solve the actions written with red.
I have 3 timers that need to stay inside the rule, else it will affect the other rules.
I dont see how i can use the trueFor here ?
I'm ready to learn ??
I see the point in splitting up the rules like rule 1 in 2 rules. However if you do it like
rule("matrix:... => Velux_Close:on; wait(00:01); Velux_Close:off")
you keep it in 1 rule, same for the other rules. While a rule waits other rules can run.
The problem it can have is if you press the button several times quickly to activate rule 1. It will call Velux_Close:off several times while it is already closed. Is that a problem?
The reason is that the same rule can trigger many  times in parallel.
If ok for rule 1 it can still be a problem for rule 2.
What you can do is to disable the rule to run again until it's finished.
Ex. rule 1
rule("matrix:... => env.rule.disable();  Velux_Close:on; wait(00:01); Velux_Close:off; env.rule.enable()")
Ex. rule 2
rule([[matrix:... => env.rule.disable();
     Velux_Open:on; wait(00:01); Velux_Open:off;
     wait(00:15);
     env.rule.enable()]])
You may not want to use the disable trick for rule 2 because people may press the 2 button again before the 15min time has elapsed and it should restart. It's doable, we can come back to that in another post.
New version for ER4 (fix39) where you just need to do
rule("matrix:... => disable();  Velux_Close:on; wait(00:01); Velux_Close:off; enable()")
    Ex. rule 1
    Ex. rule 2
         wait(00:15);
    Thank you Jan
    I will start with this
    this will work in 98% of my situations.
    and of cause - it would be interesting to learn the advanced version ... "it's doable, we can come back to that in another post".
    The last rule not testet yet
    Edited by ChristianSogaard
    p
    6 hours ago, ChristianSogaard said:
    Thank you Jan
    It depends a bit on how you want it to work.
    Given the rule
    while it is doing its 30min wait, what should happen if someone presses the button again?
    Extend the wait?, close directly and open again?
    Given the rule
    the 15min or 30min air out - the only thing i think make sense is closing the windows before time. I cant really come up with other good scenes.
    If a second close is run after window is closed. nothing happens. It not a toggle function.
    P
