pejot 0
I wonder, is it possible to show in VD (using VD) which scenes, out of 9, are currently set to Automatic and which out the 9 are currently set Manual, or at least which are set to Automatic?
I know that the definition can be modified using PUT /api/scenes/ HTTP - runConfig "TRIGGER_AND_MANUAL" vs "MANUAL_ONLY". But I am not sure how to show the current set up in the UI.
Also, I want to show it to a user that has no access to scenes (currently the user has no idea which scene is ON and which is OFF, so I believe the scene config parameter should be read and shown to him, somehow,.. )
Problem comes with HCL that it has no LUA.
