I have the Fibaro HCL and want to create the scene during the night.
I created the scene in the attachment but not working the time.
The rule in atthachment set after sunset and before sunrise, the devices are off and PIR violated.
How to create rules during the night?
Please explain better what you want to accomplish with this scene. Maybe it's also better to set your HC in English so we can better understand your screenshot?
If I guess what you want is:
If the PIR is breached/activated AND time is between sunset and sunrise AND device x AND x AND x are off THEN .......
Correct?
    Yes, correct
    I upload the new image.
    I need the turn on the light in the cupboard during the night if PIR is breached and other lights are turned off.
    I think the "before sunrise" and "after sunset" are more in absolute sense. So that probably won't work.
    If so, you better create a global variable (possible on HCL?) filled with something like "dayTime" or "nightTime". With a separate block scene change the global variable depending on sunrise an sunset and use the global variable in the above block scene.
