Help, problem with wall plug scene
I ask for your help because I would like to create a scene with a wall plug
I would like that if the wall plug exceeds 100watt it communicates me with a push that has exceeded, but only once
and when it goes below 100watt you communicate me with a push that went under, only once
in practice I would like you to notify me if a threshold is exceeded or not, but only once
can you help me?
Thanks so much
Edited by ciappi
5 answers to this question
Once a day you mean? or everytime it drops and goes back to max treshold?
create var maxtreshold and mintreshold
scene
if plug > 100 watt and var maxtreshold is off
sent push
set var maxtreshold to on
same for lowtreshold, change var if you want to recieve push again
    i am new can you do an example of variable?
    thanks so much
    i don't have a hc2, but let's give it a try
    create variable maxtreshold (with on and off
    create variable mintreshold (with on and off)
    i guess you want a push message if it reads max and if it reads min?
    first set both varaibles to off
    scene one:
    if plug > 100 AND var tresholdmax is off
    then push message "whatever"
    set var tresholdmax to on
    scene two:
    if plug = < 99 AND var tresholdmin is off
    then push message :whatever"
    set var tresholdmin to on
    this will work one time until you somewhere set both var to off, but i have no idea how often and when you want a pushmessage
    almost forgot..
    tick trigger on both plugs in scene, no trigger on the variables
    you are great
    thanks so much
    it works fine
