LUA light script
I am testing with some LUA scripting.
I have my own script for lighting in my hallway. In short:
- If Fibaro Sensor (21) sees movement
- Then start the script
- Then the lights must be to 99%
- After 7.5 min (450.000 milliseconds) then
- If SchemerJaNee (Dutch for dusk) = Yes, then dim to 20%
- If SchemerJaNee = No, then turn off
The scene works. Sometimes. But all the other scenes (mainly block scenes) aren't working anymore. I think my scene is messing up something, but I don't know what :-)
Can you help me with this??
DECLARATIONS
ACTIONS
Edited by Fabian78
16 answers to this question
What if there is within the 7.5 minutes movement, should the timer reset?
    Quote
    Yes, this would be the best.
    Edited by Fabian78
    Because this script will wait (sleep) 7.5 minuten and turn off the light (or dim).
    Ok, how do I solve this?
    With a loop like this code
    (Did some fast copy paste, didn't test anything)
    Edited by SmartHomeEddy
    Thnx. I will test it tonight.
    Goodluck
    The essence is the while - do loop. It loops 7.5 minutes, but is there is movement, it resets the timer.
    maybe test with one minute ?
    Quote
    I think that will be a good idea.... ;-)
    Is the Conditions/Triggers still necessary?
    Please try to use
    . Could be done very easily.
    In addition you can control your HCL from HC3.
    No more endless block scenes   ?
    2 minutes ago, cag014 said:
    Please try to use
    I can assure it is true ?
    yes (and also fill in the motion ID in the motion variable in the action)
    Yes. It's works!
    There was one error in the scene, but I made a correction.
    Thank you.
    Only one, I am making progress ?
    Fabian78,
    On 1/7/2021 at 7:45 PM, jorge rintaro said:
    Fabian78,
    I have only one problem...
    When entering a room, a takes sometimes a few seconds before the light goes on. Not always, but sometimes.
    How can I solve this?
