First things first - I'm not an expert, but I know my way around coding to have a nice set of features and functionality going on in my Home-automation-setup.
I think we are all caught up in the same situation about not sharing our scenes, because it ends up being to customised for individual needs, and it takes to much work to make it generic for everyone to use it out of the box.
Of course, a lot of my code and ideas is copied from very skillful guys in this forum and other places, and even though I have tailored it for my needs and based it on my fundamental setup, I hope that someone will be able to benefit from the attached files.
Just to give you an idea of what you can expect to find:
CreateGV.lua - is a scene that creates a devicetable as a globalvariable to hold a reference to all devices in my setup. The basic idea was inspired by @AutoFrank and tailored for my needs. The idea is to reference the individual devices without using the deviceID in the code. It enables you to uninstall/reinstall or replace an existing device without having to alter every reference in the code to make it work again. I changed it to be grouped by device type (instead of by room) to be able to loop through all devices by type, and added an extra layer to the structure to hold device specific properties (instead of just the ID). I have attached a copy of the devicetable (DeviceTable.json) structure to give you an idea of my use.
AutoLysNiveau.lua - is a calculator for a general lux-level in your house, based on several lux-devices paired to near by light-source that is taken into account in the calculation to generate a lux-level without fluctuation for handling lux-driven auto light on/off
LuxLightAuto.lua - is the activator for lux-driven auto light, which can be based on lux-devices or the above mentioned AutoLysNiveau.lua
MotionLightAuto.lua - is a event-/motion-driven auto light ON/OFF-handler with a lot of features - originally based on @10der's work
HouseModeChanged.lua - handler for every change to my HouseMode-globalvariable to distinguish between HOME/AWAY/NIGHT/VACATION - use this general VD_HouseMode.vfib to change housemode
AutoGeolocation.lua - handler for mobile geofence and automatic change of housemode when multible mobile devices exits and arrives at home
Last but not least I have a setup of 6 different make/model of IP-cams that is handled by my QNAP-NAS (with QVR PRO, could as well be Synology alike-setup) the QVR PRO is calling VD_Cam.vfib (handle unlimited number of cams) on detected movement and makes a callback if the current IP-cam is "armed", to start recording. Furthermore the movement is passed on (regardless of armed-state) to CamMotion.luaCamMotionLight.lua which handles auto light from cam-motion.
Enjoy ?
Edited by Bimmer
  • Thanks 2
