sorry i need to do call to my mobile phone when trgged a sensor.i read the tutrial but the voip works only on the same lan.i would do call trought internet to my mobilephone.
if you can NAT-ing VOIP ports from HCx to internet - you can call and recvd call by internet.
    but how i do a tell hc2 do a call when the device is trigged.there is no panel to do it.there is only panel notification with message and email.which port i have to natting.tks
    1) lua for HC2/HC3 is not provided as voip /sop client.
    so you should build own themepark... with RasPi / PJSUA / PHP and call PHP script from HC on alarms
    2) 5051 (SIP Port)
    • 4 years later...
    I've managed to get it working by setting up port forwarding on my router and making sure the SIP ALG was disabled. The next step that helped a lot was checking with my
    to get their list of supported codecs and required ports, then matching that info in my settings. Once that was done, the calls started going through without issues.
    Edited by vallaska
