emielstroeve 22
I'm looking for a solution to export fibaro data (lux, energy readings etc) to an SQL server. I'm also using Openhab3 to collect energy/climate related statistics and want to combine that with fibaro stats in the (MariaDB) SQL server.
So how can I export data from fibaro to MariaDB-SQL? OpenHab3 can also be used as a collector, OH3 is also feeding MariaDB.
OH3 is running on Raspberry, MariaDB on Windows.
