Hi there
Could someone please explain to me where the settings for the rooms are?
Main temperature sensor, main humidity sensor and main light sensor
What do they do and how can they be used?
Does anything affect what?
Greetings Frank
it used by heater / humidity / cooling system. AFAIK
I dont know if this make sense to your question?
/monthly_2021_01/image.png.3b476f8508b66cf7a5a198ff6c0375cf.png" />
Edited by ChristianSogaard
    Hello @ChristianSogaard
    Thanks for the information.
    That is exactly the statement that I received from other agencies.
    So the entry is only for viewing and does nothing.
    I had hoped that the entry of the room temperature sensor had an influence on the specification of the radiator thermostats, but I found that out by trying.
    To do this, you would have to be able to overwrite the radiator thermostat with an external actual value.
    That was exactly my hope.
    Greetings Frank
