- Heatit thermostats , both wired and battery operated are not appearing.
- Aeotec garage door controller not appearing
- Aeotec LED smart bulb status (ON/OFF) not updating correctly (usually says they are switched on when they are off). And the layout of the bulb in the app makes it difficult to scroll up and down without changing the bulb settings.
(All of these devices work fine in the Fibaro for iPhone app)
  • 2 months later...
    I see the app is up to version 1.11 now, but none of the above issues have changed. I is pretty annoying that my newest thermostat, which is the newly released HeatIt Z-Temp2 works fine in the old Fibaro for iPhone app, but is not even visible in the Home Center app. My only reason for having the Home Center app is because I want to use Siri shortcuts for a couple of scenes. For everything else I use the Fibaro for iPhone app.
