"No wire" buttons
i need connect two button to dual switch fgs-223.
There is not a way for wire.
How i can resolve the problem without breaking the wall?
Best regards
Hi there
You won't be able to do this without installation effort.
The FGS-223 requires 230VAC as a supply.
If you can do handicrafts and have a large flush-mounted date, you can build something like this from 2 window contacts (battery operated).
That's the only idea I have right now.
A wireless sensor / actuator needs too much power to run on batteries.
A window / door contact is a little different.
Greetings Frank
You could use a battery powered zwave controller mounted to the wall, such as Aeotec wallmote or remotec scene master zrc90. Then write scenes to monitor the buttons and control the fgs223.
    I use aeotec wallmote in the kitchen but now i must use gewiss standard button.
    Perhaps the contact door is unique way :(
