Time Switch with Fibaro Plug
Hallo,
i warnt to create a time Switch with the Fibaro Hub on HC2. I Could do it with many scenes, but that’s not nice.
6:00 the device should go on for 5 Minutes, then 10 Minutes off, 5 Minutes on, 10 Minutes of, ... til 8:00
16:00 the device should go on for 5 Minutes, then 10 Minutes off, 5 Minutes on, 10 Minutes of, ... til 22:00
Thats impossible in my mind with magic or block scenes, because i must create many many scenes. Can I Do this with one LUA scene and variables?
I have no more idea. Hope you can help me.
Thank you very much.
14 answers to this question
Hi there
Yes, that works very well with LUA.
You can do that with a "cron" job.
How much do you know programming?
I could send you my main scene, just I think it'll kill you.
Start slowly and create a block scene and then convert it to Lua.
Then you try to understand how it works.
Here are some sources of information.
However, I only have some in German (my mother tongue).
Greetings Frank
    Hello, thank you for your fast reply. In general I am familiar with programming (C, PHP, Python, ...). But with LUA I am not as good as possible.
    I think I could understand your Code (after a while). But thank you for the hint “Cron Job”. That’s a nice idea for searching.
    I am back if there are more questions ore I have the solution.
    and you could create it with two blockscenes
    Really? I didn’t find any solution to do this with 2 block scenes. Could you share your Idea with me, please?
    Add the trigger for 6:00. You can add the first device, turn it on, add the same device, turn it off and use the red (red) delay part, turn the device on with delay etc. etc. Until 8:00
    Here is an example of a holiday blockscene:
    Do you mean in this way (the time is different from the example)?
    Edited by AlexK88
    Found an error, i think now its ok
    Hi there
    Here is a possible example on the fly in LUA
    Declaration
    Action
    Greetings Frank
    3 hours ago, FBerges said:
    Hi there
    Declaration
    Action
    Greetings Frank
    It only needs to be converted to HC2 format.
    I think this wil work. Otherwise repeat the on an off cyclus in the blockscene.
    See
    .. two lines and you're done
    Hi there
    You may be right about that, but there is still the complete block All in One behind it and how many program lines does it have?
    Here the question was asked how a newcomer can do this.
    It doesn't help much to give such a chunk. I don't think my program snippet is that screaming, but it might help a newbie get started.
    In addition, you don't need a truck to get a case of beer from the beverage market if a small car does too. ?
    Greetings Frank
    7 minutes ago, FBerges said:
    Hi there
    Greetings Frank
    Yeah, as why you need expensive HC2 to turn on/off switches...?
    The code size is doesn't mater if it works properly... do you know what the code size of HC2 just to create a block scene?
    3 minutes ago, SmartHomeEddy said:
    Thank you for the great help. I did it with my posted Block Scene for the first Time. I changed the Interval from 15 to 10 minutes, because the Time between the up cycles should be 10 (not 15). But the rest will be ok. There is a little delay in the energy panel, I don't know why.
