Rasmusk 1
I had some problem with my fibaro motion sensors running on home center 3. When using a scene to turn on/off my light. There was a delay from the motion was detected to the light is on about 2 seconds. However if i use the direct association from the motion sensor to the zwave light controller it will turn on in less than 0,5 sek. 2 sec is not acceptable.
The problem however is that the logic i can use by using the direct association is very limited. It could be very nice if i could combine the scenes and direct association. So the direct association will turn on the light, but then the scenes is used to turn off the light and control when the direct association can be "activated" again.
