Motion Sensor not visible in scenes, but visible in system.
As described in post title.  One of my Motion Sensors v3.2 not visible in scenes, but visible in system. Rest of my Motion Sensors (also 3.2) visible properly in block scenes.
5 answers to this question
@Kenobiben Version 3.2 would be a Fibaro Motion sensor. What system are you using, with what firmware?
Edited by SmartHomeEddy
try to eclude and include in non secured mode
    5 godzin temu, SmartHomeEddy napisał:
    @Kenobiben Version 3.2 would be a Fibaro Motion sensor. What system are you using, with what firmware? HC2 4.60
    @akatartried that already. Seems to be specific with this unit. It's visible in a browser as ordinary Motion Sensor. Unfortunately i can't add it in a block scene. No Motion Sensor to choose. I will make a lua scene maybe...
    @Kenobiben very strange, you should see it in the blockscene as trigger. I see all my motion sensors. Like @akatar sugested, non secure mode?
    Notice
    fibaro has a very strange behavior when device associate with some internal fibaro features
    what I mean?
    ok find and plug/switch
    click on drop down with roles
    choose for example “the alarm breach” role
    ok
    after this action your switch disappeared from any actions and I at all
    The same behavior when you trying to combination switch or make group as linked device
    what about motion sensor - please send for as response
    http://ipaddress-hc/api/devices/777
    where 777 is device Iid of motion sensor
