Peppe 0
I build up a new house where the majority of the lights are strip leds controlled through RGBW2 modules, the rest of the house is based on GU10 lamps controlled through dimmer2.
Are several days that I'm trying to properly setup the RGBW2 modules whiteout success.
First of all I got stuck with the security issue, where the Fibaro support confirmed that is a know bug.
I re-added all the modules without security option and to be honest I had to made several attempts since not all the modules have been properly added at first shot.
Now I need to play with the Input/Output configuration since I have multiple white strips connected to the each module and I need to combine single outputs channels as groups.
This is the Configuration:
Fibaro RGBW2
Out1 white strip
Out2 white strip
Out3 not used
Out4 white strip
In1 momentary switch
In2 momentary switch
In3 momentary switch
In4 momentary switch
The wanted result is:
In1, In2 and In3 controlling Out1 and Out2 as single device
In4 controlling Out4 as single device
I started with the device grouping feature in HC2 but there is too much delay, after pressing the In1 button Out1 directly turn On/Off and only after completion Out2 starts.
The Support suggested to play with the associations but are two days I'm making attempts without success.
As far as I understood if with In1 I want to control Out2 I should select the Out2 device in the group 4 as multichannel device, but unfortunately it doesn't work and after hundred of attempts I'm little bit frustrated.
Is here someone that has been able to configure something similar to what I'm trying to do?
Thank you in advance!
