Hi!
Im building a quickapp to control a Tado thermostat in Home Center 3. But i'm a little stuck.. (because Tado api is not documented very well) so any help is appreciated!
What I have so far:
But I keep getting the following response status:
Quote
"Full authentication is required to access this resourceunauthorized"
I think that's because I need do assign the Bearer token from the request, but i'm a little lost how...
From this tado api guide:
 I know that this is the Curl code:
But I don't know how to translate this (completely) to the above Lua code.
    I am a lot further now and getting all the information from the api. If anyone is interested in the Tado quickapp, let me know :)
    Yes, I am interested!
    I've updated the look of the quickapp a little bit. Not everything works perfect yet, but almost there.
    Interested!
    Interested?
    • 3 weeks later...
    interested! :)
    • 3 weeks later...
    Interested as well. I see you use only the living room, woonkamer. I know we have to start somewhere but here i have like 8 heating panels with all their own temperatures plus the main thermostat. Is that something which should come out of this quickapp?
    Interested
    • 4 weeks later...
    Did anyone managed to get this quick app? I am really interested. Perhaps someone will share it with me
    Hi talkatoo,
    I am also very interested.
    thank you
    I'm also very interested !!
    Ik ben al 2 avonden opzoek naar een oplossing maar niks of niemand heeft een oplossing,
    Heb je toevallig al wat geupload ?
    Edited by Louismiller
    • 7 months later...
    Interested!! nest out! tado in . ;-)
    How is the integration going? Are you planning to publish the QA free of charge or paid? :) @talkatoo
    Looks like a strange topic. Lots of users interested, but no sign of the quickapp?
    Contacted Talkatoo once (also a Dutch guy), he was extremely busy. So still interested here, but might replace Tado for HeatIT
    I would like to ask you, what part of this QuickApp is the most interested for you? Additional graphic element below on standard widget, or maybe something else?
