Tamar 0
I want to set parameters of Aeotec TriSensor. I checked instruction, which suggests that e.g. setting a parameter 11 will change color of light on motion event report from green (default) to red.
When I do the setup of this, or other parameters though, they all are shown as 0. I do this as follows:
Go to device settings -> advanced-> configuration
Go to configuration -> add setting
Set:
Number:11
Data type: 1d (1 byte)
Value: 1
Nothing happens though (parameters are saved, but with value 0, and device behaviour doesn't change). Do you have advice on how to set those values?
Edited by TamarLink to comment
4 answers to this question
