Change the title of a push message
Is it possible to change the title of a push message?
if I use the following LUA line I always get a push message with title: Push (house name) and then the message.
fibaro: call (phoneID, "sendPush", message)
See image.
If I make an internal notification, you can set fibaro to automatically notify you by means of a push message.
However, the title of the push message is then not "Push (house name)", but the text as entered by "title" followed by (house name):
---------------- Internal notification ------------------------------
HomeCenter.PopupService.publish ({
    - title (required)
title = 'XXXX.',
    - subtitle (optional), e.g. time and date of the pop-up call
subtitle = os.date ("% I:% M:% S% p |% B% d,% Y"),
    - content header (optional)
contentTitle = 'XXXXX',
    - content (required)
contentBody = 'XXXXX',
    - notification image (assigned from the variable)
img = "",
    - type of the pop-up
type = 'Warning',
    - buttons definition
buttons = {{caption = "OK", sceneId = 0}}
I would also like to change the title of a normal push message, is this possible?
Thanks in advance.
Edited by AvdL
    Nobody??
