Problem with gateway connection
Hello!
I have two controllers: Fibaro HC2 (4.600) and Fibaro HC Lite (4.560). And they are connected via Gateway Connection in such a way that Fibaro HC2 is the main one and takes all data from Lite, it  have Lua scenes on it.
And there is one problem that spoils life.
The connection works normally only for 5-10 minutes, i.e. when the sensor states change on Lite, I see a change in HC2, but after this time, the changes in HC2 stop being displayed. At the same time, if I press the relay on HC2, it will work on Lite, and if I press from Lite, the state does not change to HC2. Only rebooting HC2 helps, but after 10 minutes, everything stops displaying again.
What could be the problem? There are very few devices on them – up to 10 pcs.
I checked the connection of two HC2 with 4.600 - the same problem-after synchronization shows, and then immediately stops updating the sensors data.
Hi Sergey,
did you find solution?
In my case helps run "synchronization", but it is manual action :-(
Anybody else?
Tomas
