Trying to do post in custom application - HC3
Guys I am trying to do a "put" in a custom thermostat that I am building that will talk to my Honeywell Evohome. The problem is that I am geting a 404. I have tried this using a "curl" which executes successfully.
I believe that something is wrong with the body but I am unable to pinpoint the issue.
Any help will be appreciated.
curl -X PUT -H "sessionId: xxxxxxxxxxxxxxxxxxxxxxxxxxx" -H "Content-Type: application/json" -d '{"Value":"21.5","Status":"Temporary","NextTime":"2020-01-22T19:00"}' 'https://mytotalconnectcomfort.com/WebApi/api/devices/yyyyyyy/thermostat/changeableValues/heatSetpoint'
function QuickApp:TurnOnHeating(tempvalue)
    self:debug("Temperature Value", tempvalue)
    local sessionId = json.decode(tostring(fibaro.getGlobalVariable("HoneywellSessionId")))
    hour=os.date("%H")+1
    hour=tonumber(string.format("%.0f", hour))
    settime=os.date("%Y-%m-%d") .. "T" .. hour .. os.date(":%M")
    local address = "https://mytotalconnectcomfort.com/WepApi/api/devices/yyyyyyy/thermostat/changeableValues/heatSetpoint"
    self:debug("address: ", address)
    self:debug("Time that will be set:",settime)
    local requestBody = {
        action = "create",
        params = {
            value = tonumber(tempvalue),
            status = tostring("Temporary"),
            nextTime= tostring(settime)
    self.http:request(address, {
        options = {
            method = "PUT",
            data = json.encode(requestBody),
            headers = {
                ["sessionId"] = sessionId,
                ["Accept"] = "application/json",
                ["content-type"] = "application/json"
        success = function(response)
            self:debug("response data:",response.data)
            self:debug("response status:", response.status)
            self:debug("headers:", response.headers["Content-Type"])
            local data = json.decode(response.data)
        end,
        error = function(error)
            self:debug('error: ' .. json.encode(error))
Error
[23.01.2021] [13:39:23] [DEBUG] [QUICKAPP192]: onAction: {"deviceId":192,"args":["Heat"],"actionName":"setThermostatMode"}
[23.01.2021] [13:39:23] [DEBUG] [QUICKAPP192]: Mode that is set: Heat
[23.01.2021] [13:39:23] [DEBUG] [QUICKAPP192]: onAction: {"deviceId":192,"args":[20],"actionName":"setHeatingThermostatSetpoint"}
[23.01.2021] [13:39:23] [DEBUG] [QUICKAPP192]: Temperature Value 20
[23.01.2021] [13:39:23] [DEBUG] [QUICKAPP192]: address:
[23.01.2021] [13:39:23] [DEBUG] [QUICKAPP192]: Time that will be set: 2021-01-23T14:39
[23.01.2021] [13:39:24] [DEBUG] [QUICKAPP192]: response data:
[23.01.2021] [13:39:24] [DEBUG] [QUICKAPP192]: response status: 404
[23.01.2021] [13:39:24] [DEBUG] [QUICKAPP192]: headers: text/html
[23.01.2021] [13:40:00] [DEBUG] [QUICKAPP192]: sessionId: yyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyyy
Edited by 03397
Sensitive Info
I don't know for sure what is wrong, but could it be the capitalisation of the keywords in the data? It differs between the curl example and your Lua example.
Also the 'create' wrapper differ but it may be another command compared to the curl example?
The same format as the curl example would look like
            Value = tonumber(tempvalue),
            Status = "Temporary",
            NextTime= settime
    I have tried you suggestion.
    I am getting the exact same error message 404.
    This thing is driving me crazy!!
