Home center lite stop working
Hello
In one of my projects I had about 30 devices in HCl and I could control them but scenes doesn't work properly, I found out memory of HCl is full, at the other hand I should add 20 new devices, so I decided to buy a home center 2 and connect them by gateway connection. I update both home centers , removed about 10 devices from HCl and added them and new devices to HC2, after 2 days I found out HCl not working and  I can't acces to web page of HCl.
Also I have this problem in another project with same situation.
Anyone knows what should I do?
Have you tried a hard reboot (remove power)?
If that doesn't work, recovery mode:
Hi, scene issue is know for HCL
Random scenes are not triggered when they should be. You need to go Configuration and push Clear measurements data.
My advice is to remove all unused measurement reports on your z-wave devices.
I have HCL system along with 40 devices - works so far.
