Quick APP Thermostat temperature setting max 30 to 90 degrees
Good day
Is there anybody that can tell me if the Thermostats that can be produced via Quick app can be increased from maximum preset value 30 dgr to e.g. 90 degrees?
6 answers to this question
yes. update
  • heatingThermostatSetpointCapabilitiesMax: 28,
to 30
there are multiple modes for Thermostates, normal, energysaving and away. Additionally one can set min and max values, e.g. (in the QA init code)
self:updateProperty("heatingThermostatSetpointCapabilitiesMax", 100)
self:updateProperty("energySaveHeatingThermostatSetpointCapabilitiesMax", 100)
self:updateProperty("awayHeatingThermostatSetpointCapabilitiesMax", 100)
self:updateProperty("heatingThermostatSetpointCapabilitiesMin", -10)
self:updateProperty("energySaveHeatingThermostatSetpointCapabilitiesMin", -10)
self:updateProperty("awayHeatingThermostatSetpointCapabilitiesMin", -10)
to get Thermostate working from -10° to 100°
/monthly_2021_02/image.png.40bd8eac170ac77e0f88443e6eceb82f.png" />  image.png.fc6e2516e38c62629d80ad6a27b2145c.png
this is of course for heating modes, there are as well cooling modes ... and modes for special thermostates. Afaik the full list of commands:
moistAirThermostatSetpointCapabilitiesMax
moistAirThermostatSetpointCapabilitiesMin
furnaceThermostatSetpointCapabilitiesMax
furnaceThermostatSetpointCapabilitiesMin
fullPowerThermostatSetpointCapabilitiesMax
fullPowerThermostatSetpointCapabilitiesMin
energySaveCoolingThermostatSetpointCapabilitiesMax
energySaveCoolingThermostatSetpointCapabilitiesMin
dryAirThermostatSetpointCapabilitiesMax
dryAirThermostatSetpointCapabilitiesMin
awayCoolingThermostatSetpointCapabilitiesMax
awayCoolingThermostatSetpointCapabilitiesMin
autoChangeoverThermostatSetpointCapabilitiesMax
autoChangeoverThermostatSetpointCapabilitiesMin
coolingThermostatSetpointCapabilitiesMax
coolingThermostatSetpointCapabilitiesMin
Edited by tinman
    Thank you Tinman and Hater,
    This was excatcly what I was looking for.
    Setting made and indeed it works.
    By the way Gentlemen,
    Is there also an option to increase the maximum setpoint value from 31 to e.g. 85 at Climate settings?
    afaik they are part of the BUI, and not QuickApp (or device class), and afaik hardcoded. I played a bit with climate panel, or acually tried to force climate profile to use my manual values, however they will get automatically reset to BUI max, as these are defined somewhere in BUI definition. For the new climate dashboard, maybe there is way to dynamically override the "aria-valuemax" and "aria-valuemin" to set new max and min values (31°, 4°), no idea, haven't played with that.
    In principle there exists already change request, to assign climate panel settings, values and climate dashboard to thermostate max/min ranges.
    Of course the App need to be fixed as well, to allow other than the hardcoded values.
    So let's maybe remind here Fibaro about that.
    @A.Socha that's for you.
    Edited by tinman
