Bradley Ward 0
I see that the maximum output of the RGBW controller is 12 amps, and that the maximum you can output to any one channel is 6 amps.
I need to control 4 RGBW 24v light strips. The specification for each strip says that is uses 60w of power, 2.5 amps.
My confusion is this: If the max on any one channel of the RGBW controller is 6 amps, am I correct in assuming that the "R" output is one channel, the "G" output is one channel, etc?
So 4 of the light strips add up to 240 watts of power, 10.0 amps. Will a single RGBW controller power all 4 light strips, or do I need to use 2 RGBW controllers?
