Same light brightnes 30>100%
Hi all,
Today a light bulb failed and was defective. I replaced it with a dimmable led bulb of 5.5watt (only one I had, can’t go to the store to buy a new one because these are closed due to covid)
Performed a new calibration but there is no difference between 30 and 100%
Below 30% the light dimms.
I have also connected a Fibaro Bypass (in combination with Fibaro Dimmer 2)
How can I solve this?
Edited by kevin
If you look in advanced tab, there is a parameter to adjust the upper limit. You could set it to 30%.
